سعود فادي
2024-06-26 18:17
The engine warning light is on, is this sound normal? I usually didn't pay much attention to it [crying].
Comments( 6 )
حسين أنس
حسين أنس2024-07-08 21:13
The yellow light is on. Could it be related to the gasoline I added?
نايف سليم
نايف سليم2024-06-26 22:35
Don't worry, all vehicles with the China VI emission standard might show this fault code. It's an issue with the emission system. Mine lights up frequently, but I haven't bothered with it. I just bought a decoder myself.
عبد العزيز عمار
عبد العزيز عمار2024-06-26 21:22
The sound is normal, but it hasn't recovered for a day or two. You should check the fault codes.
عمر سلطان
عمر سلطان2024-06-26 19:26
I have the same sound as well.
عمر سلطان
عمر سلطان2024-06-26 19:25
How many kilometers has it run? What year is the car?
سلمان أبو بكر
سلمان أبو بكر2024-06-26 19:11
How many kilometers have you driven?! If the engine warning light is always on, it's better to visit a repair shop or a dealership to read the fault codes! [I want to be alone]
Hello. What does it usually mean if the engine warning light on a smart car is on?
The self-check light on the Accent's dashboard isn't lighting up? And there's no engine warning light either.
I thought this car wouldn't be available in China, so I didn't pay much attention to it. I really love it, but I'm too broke to afford it. 🥺
What should I pay attention to if I'm considering buying a 2014 Toyota 86 with an automatic transmission?
The 4LO warning light and the engine light on the Land Cruiser are both flashing.
Here’s the situation: I just replaced the battery, but it's dead again. After starting the car, after a while, it reports a battery charging fault. Then the ABS and airbag lights also come on. When idling in place, after a while, the car will automatically shut off. When driving, it feels like it doesn't shift gears automatically, and I can't switch to manual mode either. Vehicle: Peugeot 207 1.6 Automatic. The battery wasn't great initially, and I didn't pay much attention to it, usually jump-starting the car. A few days ago, I replaced the battery. First, during driving, it started showing a battery charging fault. After a while, the ABS light came on, then the airbag light lit up as well. It's like a parade of warning lights. Now I'm wondering if it's worth repairing. What could be the issues?
What should I pay attention to when buying a used car from around 2017 that has been modified?
How much do I need to earn monthly to afford it? [crying][crying]
