The car was fine when I parked it, but the next day when I started it, the engine fault yellow light came on. The car runs fine, but the yellow light stays on. It's been almost two years; does anyone know the reason? 😢
I bought a second-hand 2014 Kia Sportage, and the exhaust smells really bad. I hadn't driven it on the highway before, but a few days ago I did, and the engine warning light came on. The check indicated an issue with the oxygen sensor. After replacing it, the error code was cleared, but a few days later it came on again. It seems fine when not driving on the highway, but as soon as I do, the light comes on and stays on. Can any experts advise on how to fix this issue?
4I just got a 2011 Mazda 5 a couple of days ago. After only two days, the check engine light came on with the code P2177. Can anyone help explain this?
5After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
6The tire pressure is fine, but the tire pressure light came on this time it snowed. What's going on?
7Hello everyone, does anyone know how to modify the daytime running lights to stay on all the time? Originally, the DRLs are on during the day when the headlights are off, but they turn off when the headlights are on at night. I want them to stay on regardless of whether the headlights are on or off.
8What does it mean when a yellow exclamation mark appears next to the start-stop light on the dashboard after sudden braking?
9The car was fine when I parked it, but the next day when I started it, the engine fault yellow light came on. The car runs fine, but the yellow light stays on. It's been almost two years; does anyone know the reason? 😢
10I drove for about an hour at night, and the battery warning light came on. Then I stopped driving. The next day, when I drove again, the warning light was off. Can you tell me what's going on and if it's serious? Thanks.
