فهد جل
2024-08-17 18:44
Is a faulty wheel speed sensor a common issue?
حسن خد
حسن خد2024-09-14 10:29
Volkswagen cars often have issues that trigger warnings even within three years. I replaced all four with new ones. 😁😁😁
عمر خليل
عمر خليل2024-09-09 19:41
Mine is broken too. How much does it cost to replace? I'm planning to get it replaced.
عبدالله بلال
عبدالله بلال2024-09-08 13:10
Changed several already [I want to be alone] It's the common problem of lousy Volkswagen.
حسين عَبْدُ الله
حسين عَبْدُ الله2024-08-26 07:31
Common issue, my car hasn't even reached 40,000 kilometers, and I've already replaced two.
سلمان أبو بكر
سلمان أبو بكر2024-08-21 20:50
This is a common issue with Volkswagen [I want to be alone].
Is the fuel consumption for the 2009 Liana 1.6 automatic reaching 10 liters per 100 kilometers because of a faulty oxygen sensor or carbon canister purge valve? I've checked the spark plugs and ignition coil, and there are no issues. Any advice from the experts?
Is there anyone experiencing a clicking sound when turning the steering wheel fully or going down a step? Is this a common issue?
Possible reasons for the acceleration issue with your 2014 2.5 4WD Renault Koleos could include: 1. Engine issues such as clogged fuel injectors or a dirty air filter. 2. Transmission problems affecting power delivery. 3. Faulty sensors like the mass airflow sensor or oxygen sensor. 4. Exhaust system blockage. 5. Fuel system issues impacting fuel economy and power. It's recommended to have a professional mechanic diagnose the problem for an accurate solution.
Can I use a wheel speed sensor bought from Pinduoduo if it’s broken?
The fault code shows two P0420s, one yellow and one red, both indicating the first bank. Is it the catalytic converter that's faulty or the oxygen sensor?
The repairman said it's a common issue with this car.
I filled up the tank a week ago, and the displayed range hasn't changed. Is the sensor broken, or is it the fuel gauge float that's faulty?
Changan Alsvin, ABS and anti-skid faults, diagnostic shows left front wheel speed sensor fault. I replaced it, but the lights are still on. The diagnostic still shows left front wheel speed sensor fault, but all the data streams are there. The fault can be cleared, but it comes back while driving. What should I do?
Changan Yuexiang, ABS and anti-skid fault, diagnostic shows a left front wheel speed sensor fault. I replaced it, but the lights are still on, and the diagnostic still shows the left front wheel speed sensor fault. However, all the data streams are present. The fault can be cleared, but it comes back while driving. What should I do?
