سعود تميمي
2024-07-25 11:00
I've had my KAMIQ for 1.5 years, and there's a clicking noise when I turn the steering wheel to the right, but not when I turn it to the left. The dealership can't figure out the cause... Anyone else experiencing the same issue?
محمد طيب
محمد طيب2024-08-03 14:20
Check the left control arm ball joint. I've encountered this situation on other cars before.
حسين أكبر
حسين أكبر2024-08-02 06:30
Ask the dealership to check the buffer pad inside the steering wheel for you.
حسن لطيف
حسن لطيف2024-07-30 09:27
Same here, the after-sales service said Volkswagen cars are just like that. [I need some peace]
سلمان باهر
سلمان باهر2024-07-26 20:25
I haven't encountered it, but it should be there.
When lightly pressing the brakes on the Vellfire, there's a slight "click" sound. Has anyone else experienced this?
Is there anyone else whose car makes a slight plastic rubbing sound when turning the wheel to the left?
My car keeps blowing the starter fuse, and I can't figure out why. I can't fix it. Does anyone else have the same issue?
I have a 2019 GS5, and since early August, there's been a buzzing noise when driving between 60-100 km/h. It feels like I'm flying a plane, especially when I turn right, it gets louder. The dealership said it was a wheel bearing issue, so I had the bearings replaced, then the tires, and even the half shaft, but the problem still isn't solved. Has anyone else had this kind of issue? Please point me in the right direction. I don't want to keep wasting money and time on blind repairs. [About to cry]
The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
After switching to 285 from the original, the car sways left and right when overtaking large trucks on the highway. Does anyone else have this issue?
When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
How to set up 360-degree imaging to display when turning left or right?
I have a question. For a 2017 Honda City with 90,000 kilometers, when I turn the steering wheel fully to the left while reversing, I hear a clicking sound. But when I turn it to the right, there's no sound, and there's no pulling to one side when driving on the highway. What could be the problem?
