I've been using 95 octane fuel for two and a half years. Should I continue with 95 or switch to 92? Thanks.
I'm asking for advice from the experts here. I have a 2016 Ford F150 XLT that's run 40,000 kilometers. I've always used 95 octane fuel. Is it okay to switch to 92 octane? Thanks!
Do I need to fill the P1 with 92 or 95 octane fuel?
Does the 2011 MDX use 92 or 95 octane fuel?
4Switching from 92 to 95 octane gasoline for your 2018 Jeep Renegade 4WD model might be beneficial for the engine.
5Should I use 92 or 95 octane gasoline for the Volkswagen Touran 2.0 naturally aspirated engine?
6How often should the transmission fluid be changed? It's been almost two and a half years, and I've driven nearly 40,000 kilometers. The dealership suggests replacing it.
7I've been using 95 octane fuel for two and a half years. Should I continue with 95 or switch to 92? Thanks.
8The new Jetta VS7 now specifies the use of 92-octane gasoline, while the 2021 version specified 95-octane. I've always used 95-octane gasoline. Has the new engine been technically improved compared to the old one?
9I've been driving my RX300 for five years. I'm torn between switching to an electric car or continuing to drive it.
10Is it okay to use 92 gasoline for a 1.4 engine? I bought a second-hand car, and the dealer filled it with two tanks of Sinopec 92. Should I switch to 95 later on?
