How do you use the key to open the windows on the 2022 Kamiq? Thanks.
How do you open the engine cover on a McLaren?
Can you only open your trunk using the key?
How do you open the hood of a 206?
4If the hazard lights don't flash and the trunk won't open when you press the key, what should you do?
5How do I change the battery for the 2022 model car key? What type of battery does it use?
6I want to ask fellow car enthusiasts! How do you activate the one-touch window lift function on the 2022 model?
7What should I do if the key of the 2022 HS7 can't open the tailgate, and the sensor can't lock the car doors? Thanks.
8Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
9How do you use the key to open the windows on the 2022 Kamiq? Thanks.
10How can the original key be used to remotely open the electric tailgate after converting to ePower?
