فهد بلال
2024-08-28 14:53
Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
فهد ثمين
فهد ثمين2024-08-30 22:28
This is the ABS (Anti-lock Braking System) being activated. For example, if one of the four wheels is suspended and you're braking, or if there's a small stone under one of the wheels while you're braking, or if one of the wheels is on a wet surface and you're braking. These situations can all trigger the ABS, which is often referred to as the brake pedal pulsing.
نايف طاهر
نايف طاهر2024-08-29 11:33
It was likely an emergency hard braking, causing the ABS to activate.
فهد فاتح
فهد فاتح2024-08-28 21:53
It's time to change the brake fluid.
Will the brake lights illuminate during regenerative braking when you are not pressing the brake pedal?
Hey car enthusiasts, have you ever experienced a jerky start, where you accelerate but the car doesn't move immediately, and then suddenly jumps forward after a few seconds?
Why does the electronic brake on the MG GS get damaged when you press the brake pedal to release it?
What could be the reason that there seems to be something blocking the brake pedal when I press the brake on a 207?
What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
Hello fellow car enthusiasts, have you ever felt that 2.0L engines are a bit sluggish when overtaking on the highway? How do you guys deal with it?
Has anyone with the Ariya tried the single pedal mode with economy? Have you noticed that sometimes when you start, there's no response when you press down, and it takes a few seconds before the power kicks in?
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
