عمر هاماوي
2024-11-01 17:40
When starting a 2017 VW Jetta from cold, once the idle stabilizes, if you try to start moving without pressing the accelerator, the car jerks as if the clutch is being released too quickly.
The battery is new, and the car starts fine when it's cold. But after driving for about ten minutes, sometimes when I stop and try to restart, it makes a squeaking sound and won't start. If I turn it off and then gently start it again, it works. I'm asking if anyone knows what might be causing this issue and if anyone has experienced something similar?
Hey folks, does anyone with a Multivan experience this? When starting from a cold engine, there's a huge vibration coming from the rear. The noise is really loud, but it goes away once the RPM drops. Does anyone know what's going on?
I want to ask about my 2019 Changan Yuexiang automatic. When I start the car cold and shift gears, it takes about 2000 RPM to change gears, like the clutch is slipping. Once the engine warms up, the shifting is normal. Do other car owners experience the same issue?
MG GS, with over 60,000 km, recently having trouble starting the car. It requires several attempts to start. Once started, five or six warning lights come on, and when pressing the accelerator, the car doesn't move, can't go over 10 km/h. It often needs to be turned off or re-shifted. Sometimes while driving, pressing the accelerator doesn't speed up the car, but the engine sounds like it's in neutral. It also jerks when moving. Local repair shops are hesitant to fix it, and the 4S shop is too far away. I'm worried the car won't accelerate on the road, which could lead to an accident. Seeking help.
How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
Hey everyone, I've been experiencing some jerking when I press the clutch on my car. What could be the reason for this? It happens when I try to shift gears at 2000 RPM.
Hello everyone! A while ago, I posted about the jerking and hesitation during low-speed starts. Recently, I found some information online suggesting that the 6-speed wet dual-clutch transmission, model DCT360, from SAIC had design flaws. Is this the transmission model used in the MG HS 2.0T? If it is, does the issue of the car not moving with light acceleration and jerking with heavy acceleration count as a common problem due to design flaws? If not, is there any way to resolve it?
When I start my 2021 Outlander, there's a popping sound in the engine bay during cold starts, but it goes away once the temperature rises. Has anyone else experienced this?
What could cause a 2017 Jetta 1.5 manual to have engine shaking when cold and stuttering on idle start? It's only done 90,000 km. 😊
