عمر هاماوي
2024-09-25 08:30
What could cause a 2017 Jetta 1.5 manual to have engine shaking when cold and stuttering on idle start? It's only done 90,000 km. 😊
Comments( 10 )
محمد هاماوي
محمد هاماوي2024-10-11 21:52
It seems like many cars have this feature. My car also has it, a 2018 1.5.
عمر جعفري
عمر جعفري2024-10-09 10:10
Just take it for a highway drive, and it'll be fine.
فهد كلثوم
فهد كلثوم2024-10-09 09:33
Misfire, cylinder misfire, ignition coil, cylinder head gasket leak.
سلمان لحود
سلمان لحود2024-10-08 15:09
Try cleaning the throttle body.
عمر هاماوي
عمر هاماوي2024-10-06 12:40
I've already ruled out the spark plugs. I changed them, but the issue persists. The throttle isn't dirty; I wiped it with a paper before.
محمد إسحاق
محمد إسحاق2024-09-29 19:24
Check the spark plugs first and clean the throttle body.
عمر هاماوي
عمر هاماوي2024-09-27 19:11
If it's a carbon buildup issue, how much does it cost to clean the carbon buildup?
محمد أسماء
محمد أسماء2024-09-25 13:32
Also, don't use low-quality gasoline for a long time. I've been consistently using the petroleum company's fuel for several years, and there haven't been any issues.
أحمد محسن
أحمد محسن2024-09-25 11:17
The most likely issues are spark plugs and carbon buildup.
فهد جمال
فهد جمال2024-09-25 10:27
Check the spark plugs and see if there's any carbon buildup.
My car has been driven 90,000 kilometers since 2013. It's shaking when idling, and there's a jolt when shifting from Neutral to Drive. Has anyone else experienced this issue? Could it be time to replace the engine mounts?
What could cause the MG ZS to idle roughly? The shaking is more severe with private fuel, while it's milder with state-owned fuel?
Hello to all the Sunshine car owners in the circle. I have a question: What could be the reason for my car's idling stutter, stutter when accelerating, and steering wheel shaking when braking? Please, I would appreciate any help with this.
When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
I have a 2012 Subaru Outback with an EJ25 engine, almost 200,000 kilometers. It has noticeable shaking at idle and stalls during sudden braking, especially when the engine is cold. I cleaned the throttle body carbon build-up recently, which improved it a bit but didn’t completely solve the problem. The engine is quite loud during hard acceleration, and I’m not sure if it’s the engine or the transmission. Also, recently it shakes at speeds over 100 km/h. Anyone experiencing the same issues?
Hey everyone, what’s the fuel consumption of your Alto automatic? I feel mine is too high, 24.5 liters only covers about 300 km. The light came on at 287 km. Also, my idle speed when starting cold is around 1500, but it goes back to 1100 once the engine warms up. Is this normal for fuel consumption and idle speed?
The 2023 model 3.0 is shaking a lot at idle, and there's a buzzing noise when starting. Does anyone know what might be causing this?
What could cause intermittent jerking at idle in a Jetta 7 after two years?
What could cause a car to shake when starting cold?
Volkswagen Volkswagen Jetta
Volkswagen JettaTBDGasoline & Petrol
