سعود جلال الدين
2024-05-15 08:20
What could be the issue if my manual Jetta's transmission makes a rumbling noise, but the sound disappears when I press the clutch?
محمد وي
محمد وي2024-05-25 13:27
Release bearing
فهد صباح
فهد صباح2024-05-24 21:48
Issues with the first and second bearings of the transmission
حسين إياس
حسين إياس2024-05-19 00:00
Check the transmission. In theory, manual transmissions are maintenance-free for life.
There's a noise coming from the transmission, but when I press the clutch, it stops. The dealership said it's an issue with the clutch disc, and they've already replaced it. But the problem still isn't solved!
The clutch on the 2.3T manual Ousheng makes a clunking sound when released halfway.
This car is overall okay, but the manual transmission clutch isn't very user-friendly. I bought my car in 2020, and it's run 23,000 kilometers. In the city, where the clutch is used frequently, it gets harder the more I press it. Do any of you guys have this issue?
Is there anyone with a Levante experiencing a ticking noise when idling after warming up the car? The noise disappears when you press the accelerator a bit. What could that sound be?
When I step on the clutch of my Mitsubishi ASX manual, why does it make a buzzing sound, like the sound of accelerating?
The clutch on my 2011 Suzuki SX4 1.6L manual is heavy. What's the issue? Is your clutch also heavy?
Why does my Sunny manual stall frequently with jerking? I never had this issue before with a manual. Could it be that the clutch needs replacing?
Volkswagen Jetta 13 manual fashion 1.6 has a noise when turning the steering wheel. There is no sound when the steering is turned in place, but when driving and turning the steering wheel to the limit, it makes a noise. What could be the reason?
1. Does anyone know if it's normal for there to be a "thud" sound when quickly releasing the clutch from first to second gear in a manual Suzuki Swift? 2. When pressing the clutch to engage first gear, sometimes there's a "thud" sound near the left foot. What's the issue?
Volkswagen Volkswagen Jetta
Volkswagen JettaTBDGasoline & Petrol
