What brand is the original battery of the 2017 Jetta?
Does anyone know what brand the four original loudspeakers in the Atuco are?
Should I replace the brake pads with better ones or go for the original ones? What brands do you guys usually choose?
What should I pay attention to when maintaining a Vitara 1.4T automatic? Which brand of engine oil and filter is better? How often should the air conditioning filter be replaced? At how many kilometers should the original spark plugs and brake fluid be replaced, and what brand of battery is recommended to be replaced with?
4What brand of battery does Subaru XV use?
5What brand is the battery in your 3rd generation Haval H6? Mine is Leoch.
6What brand are the original brake pads, or can anyone recommend a good type of brake pads? Thanks!
7Hey guys, what brand are the original tires? What brand do you all switch to for replacement?
8How often do you guys replace the battery, and do you stick with the original brand?
9My car battery is dying, and I plan to replace it. What brand of battery is suitable for a 2011 Nissan Sunny? Any recommendations?
10What could cause a 2017 Jetta 1.5 manual to have engine shaking when cold and stuttering on idle start? It's only done 90,000 km. 😊
