The high beams of the car are not illuminating the road but are pointing to the sides. What could be the problem and how can it be fixed?
My X95 manual's headlights have an issue. When I start the car and turn on the high beams, they don't work at all. But for a few seconds, they work fine. When the car is parked and I turn on the high beams, everything is fine. What could be the problem?
How do I turn on the high beams?
How to turn on the high beam headlights?
4Has any 80 owner adjusted or upgraded the high beam distance? Can the service center do it? The illumination is really too short, can't see the road at all at night. [Facepalm][Facepalm][Facepalm]
5How do you turn on the high beam for the 206? The low beams can be turned on and the high beams can be activated by pulling the switch back, but it can't be pushed forward. What's going on?
6How can I adjust the high and low beam headlights inside the car?
7The high beams of the car are not illuminating the road but are pointing to the sides. What could be the problem and how can it be fixed?
8I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
9For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
10How to fix the issue of the gear position light not illuminating sometimes for the '21 model Compass when in Reverse (R) gear?
