أحمد بدر
أحمد بدر
Nov 8
I've got a 2017 Jetta with 90,000 kilometers on it. After a major service, there's a plastic rattling noise coming from the AC area when driving at low speeds. What could be causing this?
سعود عبد المجيد
سعود عبد المجيد2024-11-21 22:25
I also have a 2017 Jetta. When it's cold and I start the car with the AC on, there's a plastic rattling sound. Once it warms up, it goes away. [I want some peace] I've never figured out what's going on.
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
Hi everyone, I need some advice. I bought a second-hand 2017 F150 XLT model, not sure from which country. Here's the issue: No matter what the setting is, when I shift gears, the low beam lights turn on. If I turn off all the lights, the daytime running lights don't come on, but when I shift gears, the low beam lights turn on. When the automatic headlight setting is on, the daytime running lights come on, and in park mode, the low beam lights don't turn on, but after shifting gears, they do. I'm wondering what could be causing this and if there's a solution?
Where can I get a comprehensive inspection for an Acura MDX? I just got a 2010 model, and there's a strange noise coming from the front right when I accelerate at low speeds, but I can't figure out the cause.
I have a 2012 Jeep Compass. Recently, when I turn on the AC, there's a clicking sound coming from the glove box area, but it stops after a few clicks. Also, when I'm turning at low speeds, it feels like the rear wheels are stuck, causing the car to vibrate and the rear wheels seem to be rubbing or bouncing on the ground. Has anyone experienced similar issues?
Hey car enthusiasts, I've got a 2014 Scirocco 1.4T. When I give it too much gas while starting, the car makes a rattling sound, like "da da da," and there's a strange noise! Anyone know what might be causing this and where the sound is coming from? Looking for advice from experienced car owners!
If you're looking to buy a used car with a budget of 40,000 RMB and you've got your eye on models like Lavida, Sylphy, Sagitar, and Jetta, here's a brief rundown: 1. **Lavida (朗逸)**: Known for its reliability and decent fuel economy. Look for models from around 2012-2015 for a balance of price and condition. 2. **Sylphy (轩逸)**: Comfortable and spacious, good for city driving. Consider models from 2013-2016. 3. **Sagitar (速腾)**: Offers a solid driving experience. Models from 2012-2015 could be a good fit for your budget. 4. **Jetta (捷达)**: Durable and economical, a popular choice for many. Look for models from 2012 onwards for better features. For city commuting, all these options are suitable, but it ultimately depends on your personal preference regarding style, comfort, and brand loyalty. Make sure to check the car’s condition and service history before purchasing.
I've got a T-Roc 1.5T for about a year now, and did the first service at 4,000 km. The dealership said the second service is due either after a year or at 10,000 km. Now it's at 11,000 km, and I'm feeling that the low-speed acceleration isn't smooth. Should I just go and change the oil outside? The dealership mentioned that 10,000 km is too long.
The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
Hey fellow car enthusiasts, I've got a 2023 2.0T RuiShang and there's a strange noise when starting up. After starting, there's a "boom" sound after a little while. It happens every time, and it seems to be coming from near the driver's side door, around the left front wheel area. I've taken it to the dealership, but they couldn't find the cause. Has anyone else experienced this?
What could cause a 2017 Jetta 1.5 manual to have engine shaking when cold and stuttering on idle start? It's only done 90,000 km. 😊
Volkswagen Jetta
Volkswagen JettaKWD 5,950 ~ 8,895Gasoline
