I have a 2009 automatic limited edition Jetta. The EPC light keeps coming on. I've cleaned and replaced the throttle body and also replaced the accelerator pedal, but the light still comes on intermittently. I'm not sure if this issue is specific to this automatic model or if it's common in others too.
Even after replacing the spark plugs, camshaft sensor, and cleaning the throttle body, my 2014 Peugeot 301 is still having trouble starting. Any ideas on what could be the issue?
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
DIY Cleaning of Toyota Verso Throttle Body
4I have a 2007 Touran, automatic 1.8t. It jerks noticeably during acceleration. When idling while parked, the RPM intermittently drops by 100-200, and the car lights dim. What should I do? (I've previously cleaned the fuel injectors and throttle body.)
5Do I need to perform adaptation after cleaning the throttle body?
6Hey everyone, should I replace the throttle body of my 206 with an aluminum one or a plastic one?
7Hello fellow car enthusiasts, have any of you cleaned the throttle body before? I've heard that cleaning the throttle body on an MG3 is quite a hassle, taking up to 5 hours and costing 500 bucks.
8Hey guys, how do you clean the throttle body on your MG3?
9After cleaning the throttle body yourself, the engine warning light came on. It doesn't affect driving, but how can you resolve this?
10Hello car enthusiasts, does the 2021 Jeep Compass 1.3T need a throttle body cleaning?
