I bought my automatic transmission car in July 2017, and it has run 120,000 kilometers. I've replaced the battery twice, a few bulbs, the ABS wire, and the windshield washer reservoir. Now, the front windshield washer isn't working, and the steering wheel feels a bit heavy (very slightly). Regarding the 120,000 kilometers, I want to ask if anyone has experienced changes in steering wheel effort?
Has anyone here modified a multifunction steering wheel?
Has anyone installed an Android navigation system? Can it support switching songs with the steering wheel controls?
Is it normal for the steering wheel to shake when driving at 120 km/h on the highway after the car has been driven for 100,000 kilometers?
4Has anyone bought a steering wheel cover for the Fengfan? Please share the link.
5Recently, on the highway, my steering wheel was shaking. Has anyone else experienced this?
6Volkswagen Jetta 13 manual fashion 1.6 has a noise when turning the steering wheel. There is no sound when the steering is turned in place, but when driving and turning the steering wheel to the limit, it makes a noise. What could be the reason?
7I bought my automatic transmission car in July 2017, and it has run 120,000 kilometers. I've replaced the battery twice, a few bulbs, the ABS wire, and the windshield washer reservoir. Now, the front windshield washer isn't working, and the steering wheel feels a bit heavy (very slightly). Regarding the 120,000 kilometers, I want to ask if anyone has experienced changes in steering wheel effort?
8I have a couple of minor issues with my Touareg 3.0, wondering if anyone else has experienced the same: 1) After refilling the windshield washer fluid, it leaks onto the ground. The mechanic suggested that it might be a crack in the connecting hose, causing the fluid to spill out. It doesn't affect usage. 2) Occasionally, when driving at low speeds in traffic, there's a slight squeaking sound when turning the steering wheel. It doesn't happen all the time and doesn't seem to have much impact.
9What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
10Hello fellow car owners, for a 2016 model 1.4T with 120,000 kilometers, and the left front headlight has been replaced, what would be a reasonable purchase value?
