عمر عدي
2024-10-03 20:16
Hi everyone, I have a 2015 Volkswagen Jetta with a manual transmission. I'm having trouble turning the key in the ignition; it takes several tries and some jiggling to get it to turn. Does anyone know what might be causing this? Any advice would be appreciated. Thanks!
I'm looking for advice on my 2016 Volkswagen Multivan 4WD that's experiencing severe tire wear. I've done a wheel alignment, but it hasn't resolved the issue. Any insights would be appreciated.
After connecting the V40 via Bluetooth, is there no sound from the navigation on your phone? Tried several times and you can only turn off Bluetooth.
I have a 2015 Honda City. Sometimes it takes two or three attempts to start. What's the issue, experts?
Does the 2015 Jetta 1.6 manual have a trunk light or not? If it does, could you please provide a picture? Thank you!
Does anyone have the repair manual for the 2015 five-door Mini Cooper? A Baidu Cloud link would be greatly appreciated, thanks a lot!
Has anyone replaced the shock absorber bushings or other bushings on a 2015 Jetta? As for the engine mount rubber, if it's not severely damaged, should I continue using it?
Volkswagen Jetta 13 manual fashion 1.6 has a noise when turning the steering wheel. There is no sound when the steering is turned in place, but when driving and turning the steering wheel to the limit, it makes a noise. What could be the reason?
Why does my 2021 manual Santana sometimes have no response when I try to start it, requiring several attempts to ignite?
If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
Volkswagen Volkswagen Jetta
Volkswagen JettaTBDGasoline & Petrol
