Hey everyone, what's your idle RPM? Is 800 normal for you guys?
What's the idle speed of your Mazda 3 when starting cold? Mine is over 1000 RPM.
Hey guys, I have a 1.6 manual Liana. At what RPM do you usually shift gears?
It's normal for your NV200 to have a high idle speed of 2000 RPM when you start it cold, and then drop to 800 RPM after about a minute. This process helps the engine warm up. However, if it feels inconvenient, you might want to consult a mechanic to see if any adjustments can be made.
4Has anyone experienced idle running at 1000 RPM when the temperature is 35 degrees, and then it returns to normal at 800 RPM when the temperature is 26 degrees? What's going on? Please help.
5Hey everyone, is it normal for the car's RPM to stay around 1200 even when I release the accelerator while driving? The idle speed is only 800 RPM when parked in neutral. Is it the same for you guys?
6Hey guys! What grade of gasoline are you all using for your Patrol?
7The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
8It's normal for the idle speed to fluctuate when you turn on the air conditioning in a 2013 1.6 manual fashion model. Sometimes the RPM might go up to around 900 or almost 1000, and other times it might be around 800. If you restart the engine and the RPM goes back to around 800, it's usually not a cause for concern.
9My Zhilong 2022 model 2.0 has reached 20,000 kilometers. When the engine is cold-started, there's a "dang dang dang" sound at 1500 RPM, but it's gone at 800 RPM. Is it the same for you guys?
10Hi friends, what is the idle RPM for your GAC Emkoo after starting the engine?
