علي حكم
علي حكم
Jul 10
Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
Comments( 6 )
فهد توفيق
فهد توفيق2024-10-08 15:18
Check if there's too much carbon buildup on the throttle body [I want to be alone].
2
أحمد شمس
أحمد شمس2024-09-18 16:39
Fixing the valve body, don't ask me how I know.
2
حسين شمس
حسين شمس2024-09-18 13:49
Not sure what's going on.
حسين شمس
I've been experiencing the same issue as you these past couple of days. While driving, suddenly the accelerator stops responding. If I release it and press it again, it works fine.
علي حكم
علي حكم2024-08-02 19:08
When you release the accelerator, you need to press the brake to slow down, and then press the accelerator again to speed up.
2
أحمد شمس
أحمد شمس2024-07-12 12:31
This situation is called "gear slipping." This is how AT (Automatic Transmission) works sometimes. The engine speed and the car speed don't match, so the computer doesn't know which gear to engage, and it ends up in neutral. Once you release the accelerator and the engine speed matches the car speed, it engages the gear again, and then you can accelerate. Pay attention to see if this is what's happening.
When stuck in traffic, frequently braking and accelerating might lead to no response from the gas pedal. You'll need to idle forward a bit before the accelerator responds, or you can restart the engine to temporarily fix the issue.
Why does the electronic brake on the MG GS get damaged when you press the brake pedal to release it?
What could be the reason that there seems to be something blocking the brake pedal when I press the brake on a 207?
Hey folks, I pressed the hill descent control on my 2014 Koleos, but nothing happened. What's going on?
I have a 2017 New Santana, and occasionally it won't start. If I wait a while or press the gas pedal, it starts. Can someone explain what's going on?
Hey guys, need some help! Has anyone experienced the car suddenly braking on its own? The dashboard shows braking, but there's nothing in front.
Help, everyone! Has anyone experienced this? While driving, the dashboard suddenly shows "brake," and the car brakes automatically, even though there's nothing in front.
Why does my car suddenly feel heavy while driving? It always feels like the brakes are on, and it won't move unless I press the accelerator hard...
Volkswagen Jetta
Volkswagen JettaKWD 5,950 ~ 8,895Gasoline
