عبدالرحمن موجا بطاقة تعريف
2024-07-03 21:33
Has anyone replaced the shock absorber bushings or other bushings on a 2015 Jetta? As for the engine mount rubber, if it's not severely damaged, should I continue using it?
محمد أسماء
محمد أسماء2024-07-03 23:24
There are no obvious issues. Generally, there's no need to replace it. Jetta rarely breaks down.
Why does the car make a humming noise at 40 mph? The noise is very loud, and the shock absorbers have been replaced.
Hey folks, the car is uneven on one side, the driver's side is 3cm lower. I've replaced all the springs and shock absorbers, and also changed all the chassis bushings, but it's still the same. The driver's side leans heavily when turning. Can any experts offer some advice?
I'm considering changing my shock absorbers. Should I go for Bilstein B4 or Tein EnduraPro Plus? Or do you have other recommendations?
Can the rubber bushings be replaced? The car makes a lot of noise when driving over bumpy roads.
Has anyone here ever changed the front shock absorber top mount on an Ertiga by themselves? Is it possible to replace the front shock absorber top mount without removing the shock absorber itself? How do you get the top mount off? Any guidance would be appreciated. [Embarrassed face]…
I accidentally hit the curb with my left rear wheel and the tire got damaged. During the four-wheel alignment, they said it couldn't be fully adjusted. If the tire is damaged, does it really require changing the shock absorber? Is it really that serious?
Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
How much does it cost to replace the front right shock absorber on a 2019 GS5? Should I replace just one or both? 😢
2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
Volkswagen Volkswagen Jetta
Volkswagen JettaTBDGasoline & Petrol
