For a 10-year-old black Jetta, when lightly pressing the brake, the ABS engages, and at around 10 mph, the ABS starts working. What have others replaced to solve this issue? [facepalm]
A few questions about the old Levante for the experts here. I bought the Levante as soon as it was released, from the first batch. 1. When in traffic and following at low speeds, the car jerks noticeably. Sometimes when I lightly press the brake and then the accelerator, the car suddenly jerks forward. 2. In cold conditions, the car can't move. It needs to warm up first; otherwise, the accelerator becomes very sensitive and only normalizes once the car is warm. 3. This is the most uncomfortable issue: the steering feels unstable. Especially on ring roads with uneven surfaces due to heavy trucks, the steering wheel moves erratically. I have to hold it firmly with both hands, or it will sway. I would appreciate any expert advice on these issues. Thank you very much!
Does anyone know why the Volvo V40 T3 version feels weak during acceleration around 60 mph, and why the steering wheel shakes when lightly pressing the accelerator?
I bought a second-hand Kia Sportage that's 10 years old. When going over bumps or speed bumps, the front chassis makes a creaking noise. I asked a repair shop, and they said it's likely the stabilizer bar bushings have aged. Replacing the two front stabilizer bar bushings would cost over 200, but they also mentioned that changing them might not necessarily solve the problem. Do you think it's necessary to replace them?
4Has anyone experienced this: when driving normally and approaching a traffic light, you brake and almost come to a stop but not completely, and at around 10 mph the RPM fluctuates while the gear has already dropped to second gear?
5After changing the drive shaft of a 12-year-old Korean imported car, it makes noise when you press the accelerator, but the noise stops after 2000 RPM. Fellow car enthusiasts, have you encountered this situation? How did you solve it?
6The 10-year-old 1.5 manual car experiences severe vibration in the gas pedal at 3000 RPM in any gear, making it difficult to press. Does anyone have a solution for this issue?
7Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
8For a 10-year-old black Jetta, when lightly pressing the brake, the ABS engages, and at around 10 mph, the ABS starts working. What have others replaced to solve this issue? [facepalm]
9When lightly pressing the accelerator at low speeds, there's a slight jerk, and when the RPM drops below around 1100, there's a dragging feeling. What could be the problem?
