عبد العزيز مرشد
2024-12-02 17:48
Will using the heater while charging damage the battery?
فهد تاج الدين
فهد تاج الدين2024-12-03 12:16
The battery can either charge or discharge at a time; it can't do both simultaneously. So, there's no impact.
محمد مبارك
محمد مبارك2024-12-03 09:12
An electric car is just a tool, no need to be so particular about it. It's quite durable.
أحمد نور
أحمد نور2024-12-02 18:58
No, I used the charging station's electricity.
Can it be equipped with a generator to charge while driving?
There's a strange smell when using the heater with the recirculation mode in winter.
How to properly use the Polestar 2 battery, which is better between fast charging and slow charging, and do I need to regularly calibrate the battery? 😵
Is there anyone who has experienced the car cigarette lighter charger not charging the phone when it's not in use, and the battery level actually decreasing instead of increasing?
Does your car battery often run out of charge?
Will disconnecting the battery for a long time in a 301 cause damage to the ABS pump? [Cheers]
Is engine internal cleaner useful? Will it damage the engine?
Can I use the air conditioning while charging the AION on high-voltage charging? How can I do it without damaging the battery and the small battery? Thanks!
Has any owner of the 3-motor version of the XP noticed a 4% drop in battery health after six months? I personally feel that I've taken good care of the battery, usually charging between 50% to 80% (slow charging), rarely using fast charging, and charging to 100% no more than five times. When not in use, I keep it plugged in and haven't driven aggressively or used the straight-line speed mode. Despite this, the battery health has still dropped by 4% in six months. Is anyone else experiencing the same thing?
Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
