عمر ياسر
2024-12-04 22:35
The ID3 is an A0 class car, with a length of 4260 mm and a weight of 1760 kg. I happened to see the Tesla Model 3, which is a mid-size car, with a length of 4720 mm and also weighs 1760 kg.
عبد العزيز عائشة
عبد العزيز عائشة2024-12-06 10:03
It's a standard A-segment car, not A0.
عمار خالد
عمار خالد2024-12-06 06:45
The ID.3 is on the heavier side; ideally, it should be around 1.5 tons. The weight reduction isn't handled well.
علي عَبْدُ الْعَزِيز
علي عَبْدُ الْعَزِيز2024-12-05 20:55
The ID series uses an impressive amount of high-strength steel. Additionally, the battery protection is solid, with substantial materials contributing to the overall weight. Some might argue that this reflects Volkswagen's lag in lightweight technology.
محمد حارثي
محمد حارثي2024-12-05 13:03
What about the wheelbase?
أحمد نور
أحمد نور2024-12-04 23:24
So, the Trumpchi GS3 is really well-built. For a car priced at 120,000 RMB, it offers the safety and reliability of a 200,000 RMB car. 😄
Hello everyone! My brother's about to order a car. He's interested in the LTD with full-time 4WD for driving on highways in wet weather but also likes the Offroad version with rear locker + KDSS. So, I have a few questions: 1) Can the LTD have a rear axle locker installed? How about the ARB air locker, is it a non-destructive modification, and how's the quality? 2) In rainy or snowy weather with the Offroad version, what happens if you drive fast in two-wheel drive? Isn't it unsafe due to slipping? If you switch to H4, does it have a center differential, and what's the maximum speed you can go (80 km/h)? 3) If we end up buying the LTD, can we modify it with the TRD front bumper? The TRD front really looks good. Thanks, everyone!
Is the Trumpchi GA8 considered a mid-to-large-sized car? The Buick LaCrosse disagrees, as its length and wheelbase are longer than those of the GA8. So why is the LaCrosse classified as a mid-sized car while the GA8 is considered mid-to-large?
Considering the recent price drop of the Tesla Model S/X Plaid and the fact that next year, purchases over 300,000 will require a purchase tax, will the ELETRE also see a price reduction?
Choosing your first car is always exciting! Between the Hongqi E-HS9 and the Mercedes E-Class, both have their own unique features. If your wife is prone to motion sickness, comfort is key. Generally, the Mercedes E-Class is known for its smooth ride and luxurious interior, which might provide a more comfortable experience. However, the Hongqi E-HS9, being an SUV, offers a spacious cabin that could also be beneficial for comfort. It's best to test drive both to see which one feels better for your needs. 😊
I'd like to ask everyone here, what are the wheel parameters for the Brilliance V3, and how much does each one weigh approximately? Also, if I want to reduce the unsprung weight without changing the size of the Brilliance V3's wheels, which brands of wheels would be suitable?
Chery Arrizo 3, sometimes there's a noise above the glove box. When driving, it usually stops, but after turning off the engine, closing the car door might cause the noise again. There's also a similar sound inside the passenger side B-pillar seatbelt. I want to take apart the dashboard to see if something is loose inside, but I'm not sure where to start. I've previously removed the bumper to install a loudspeaker and added a central control screen with a rearview camera. But I'm not sure how to start with the area above the glove box.
