نايف إدريس
2024-11-25 21:31
Is the optional reversing camera for the base model included with the car, or is it added separately at the dealership?
عبد العزيز محمود
عبد العزيز محمود2024-11-26 10:39
It's best to choose the original parts. I selected additional parts from the dealership when I got my car in September, and they still haven't been installed. They say the manufacturer's decoding system hasn't been sent to the service station yet, and the 2025 model can't be decoded.
أحمد نور
أحمد نور2024-11-25 22:59
Factory-equipped.
20
عبدالرحمن عفان
عبدالرحمن عفان2024-11-25 22:38
The optional features for the APP are directly provided by the manufacturer.
I've upgraded my 2009 Scirocco with the 187b head unit, but the reverse camera doesn't switch the screen when reversing, although the radar works fine. Interestingly, the reverse camera works normally when the car is off, but not when the engine is running. I've already replaced the head unit and the reverse camera, but the issue persists. Any experts out there who can help?
If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
Which car is more suitable for daily use compared to the base model of the 911?
I'm looking to install a central control screen with a reverse camera on my 2014 Peugeot 301. Any recommendations, fellow car enthusiasts?
Hello fellow car enthusiasts! Why is the reverse camera on my 2013 Sharan 2.0T showing the left and right sides reversed?
The reverse camera is seriously lagging, and the dashcam function isn't working. Does anyone else in the car enthusiast group have the same issue?
Has anyone upgraded their car's screen? 😁 I have the 2011 automatic base model and I'm just looking to see if anyone has done it before, just want to add a reversing camera.
The 2017 flagship model has a reverse rearview camera that doesn't tilt down, even though the setting is checked in the car's system.
2023 model You Edition, rear-wheel drive, four seats, 14,000 km, planning to sell, no additional options included.
Is it necessary to choose additional options for the G80, or is it not available as a base model?
