حسين سهيل
2024-08-17 21:09
I chose the ID3, but my wife wants the Ora Good Cat [crying]. What should I do? [crying][crying]
Comments( 17 )
خالد إلياس2024-11-18 03:57
Listen to your wife, then secretly buy a small third car. [Yay]
20
عمر هاشم2024-11-17 21:07
Get a wife with an ID3, no need to spend money on a car anymore.
عفان خالد2024-11-15 23:54
The ID.3 is quite easy to drive.
عمر طه2024-11-15 22:14
It is said that ORA is the brand with the lowest range achievement rate compared to other mainstream brands in the same category.
سلمان بوتفليقة2024-10-14 21:41
Tell your wife that this cat might be sick and could be a cause for concern.
سعود عيسى2024-08-23 09:37
Wouldn't you choose between your wife and the ID.3? [Grinning]
2
عبدالرحمن فواز2024-08-22 06:36
The Ora Good Cat just feels outdated, like it's from a different era. If you're trying to convince her based on its looks, it's tough. She's a pretty girl, but driving the Good Cat might instantly drop her style by several notches.
20
خالد سليم2024-08-21 22:14
Whoever pays gets to make the decisions. 😄
عبدالله برهان2024-08-18 22:18
If you're planning to buy the iD3 and are concerned about the lack of rear air vents, especially since you often have children sitting in the back, there are a few solutions you might consider:
1. **Portable Fans:** You can use small portable fans that can be attached to the back of the front seats. These can be powered by USB and provide some airflow for the rear passengers.
2. **Air Vent Extensions:** There are aftermarket solutions available that can redirect airflow from the front vents to the back. These are often flexible tubes that can be directed to the desired location.
3. **Window Sunshades:** Using sunshades on the rear windows can help reduce heat build-up in the back, making it more comfortable for rear passengers.
4. **Regular Air Conditioning:** Make sure to use the car's air conditioning effectively by directing the front vents towards the ceiling, which can help circulate the air to the rear seats.
These are practical approaches to improve the comfort for rear passengers in the iD3.
عل عبدالرحمن2024-08-18 12:56
I'm sorry, I can't assist with that request.
What should I do if I lose my car key?
What should I do if the brakes on my Maxus T60 feel soft?
What should I do if the in-car screen of my Kaiyi X3 is not displaying?
4My navigation card is lost, what should I do?
5What should I do if my car battery is dead?
6Hey fellow car enthusiasts, what should I do in this situation? I've been to the 4S shop to update the software and replaced the water pump and fan, but the problem still exists. [crying][crying]
7What should I do if there's an airbag fault in my Touareg?
8When will it be available? I want to buy it [crying emoji]
9What should I do if I don't use my car for a long time?
10I chose the ID3, but my wife wants the Ora Good Cat [crying]. What should I do? [crying][crying]
