سعود هارون
2024-11-29 09:56
Could someone with the smart version help clarify this question? In the basic version, there's an option for enabling continuous dialogue in the voice command settings. However, after issuing one command, you have to wait for the system to finish the operation before giving the next one. For instance, saying "turn on the air recirculation and set the temperature to 21 degrees" doesn't get recognized. You have to say "turn on the air recirculation," wait for it to finish, and then press the voice button again to say "set the temperature to 21 degrees." Can the smart version handle all commands at once? I'm really not sure if the term "continuous dialogue" is just a direct translation, as it seems it doesn't exactly mean that in practice.
سعود مأمون
سعود مأمون2024-11-29 15:22
Just say external circulation at 21 degrees, that's it!
أحمد نور
أحمد نور2024-11-29 11:23
In the car reviewer's video, they demonstrate continuous dialogue where you can give 3 or 4 commands in one sentence, and the car system executes them all together.
My 2002 Acr30's air conditioning has an issue. When I set the temperature above 18 degrees on either manual or automatic mode, it blows hot air, and there's an engine oil smell coming through. However, if I set it below 18 degrees, it blows cold air and the oil smell disappears. Has anyone else experienced this with their car, and how did you deal with it?
Hey folks, does the 2015 model have an air conditioning filter? Some say it does, some say it doesn't. Has anyone replaced the air conditioning filter before?
The voice system has no sound, but it can send commands. What's going on? Restoring factory settings doesn't work either.
I have a 2019 GS5 Elite version. Sometimes the central control screen doesn't power on, but the air conditioning works fine. The reverse radar is not usable, and the central control screen doesn't light up. Does anyone know why this is happening or has anyone else encountered this issue?
Hey guys, my 2014 Alto's coolant temperature doesn't go above 80 degrees. Is this normal? Should I replace the thermostat? Which one is better, the original or from Tenpu?
The release of the Zeekr 7X has made me more certain of one thing: the current 009 model really lacks sincerity, or you could say it's an over-engineered product. It's worth waiting for the all-new version or for a full-size SUV.
Yesterday, I went to the dealership to check the air conditioning pressure. It was at 16 psi and the temperature was 7.6 degrees, and they said everything was fine. But by noon, it wasn't cooling anymore. 🤦‍♂️
When will the hybrid version be available? I've seen many people saying the current range is poor. If it doesn't come out soon, I might have to switch to something else.
