I have a Chevrolet Aveo and the air conditioning blowing only hot air i don't know why
The rear air conditioning vents are not blowing cold air?
Hey everyone, just wanted to ask: Why does the JETOUR X95 blow hot air when I turn on the seat ventilation? Thanks!
4When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
5Geely air conditioner only blows on the front windshield, settings don't work, and it fixes itself after a few days. Does anyone else have the same issue?
6The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
7The temperature settings for both the driver and passenger sides are the same, but the passenger side is blowing hot air while the driver side is blowing cool air. What's going on, experts?
8My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
9When I use the air conditioning for a longer time in the summer of 2019, the cold air stops blowing inside the car. Does anyone know why?
10Why does the air conditioning blow cold air while driving, but not when stopped at a traffic light?
