رشيد محمد
Feb 20
Hyundai Elantra owners, what’s the most common repair issue you’ve faced? Is it expensive to fix here in Saudi?
Has anyone encountered engine noise in a 2019 F150 with 60,000 km? The mechanic says it's a common issue and suggests dismantling the engine to fix the gears.
What's the fuel consumption for a 1.6 automatic? Are there any common issues?
Maybach S-Class owners, what has been the most disappointing aspect of the car since you got it?
4Is oil consumption a common issue for the Mitsubishi Eclipse Cross? How should it be repaired?
5Has anyone here ever replaced a transmission? What issues can get you a warranty for the transmission?
6Is it a common problem that the wipers on the T99 couldn't be fixed after visiting three repair shops?
7Looking for real car owners' opinions on the 2017 2.4 High-Performance version. What are the common issues?
8The screen was working fine until the afternoon, but after being exposed to the sun all day, it started to malfunction. What can I do to fix the screen issue without replacing the car stereo? I'm concerned about the repair cost being too high. Is there a way to fix it myself?
9The EPC light came on twice, but restarting the engine fixed it, and it hasn't appeared again. Fellow car enthusiasts, what could most likely be the issue?
10Is the 2014 Volvo V60 Inscription worth buying? What are its common issues?
