حسين أسماء
2024-07-10 17:25
Why do the original tail brake bulbs of the Accent last the longest, but the replacement bulbs don't last as long? They start flickering after just three to five years?
Is a 2007 Hyundai Accent, 14,000 km, manual high-end model, with four tires changed last year, insurance expiring in August next year, in good condition, original paint, with minor scratches, expensive for 12,000?
I just went to the 4S shop today, and I can't upgrade the car system. The original 360 camera is not clear and can't be calibrated. Regarding the transmission defect issue, the after-sales service at the 4S shop will apply to the manufacturer and get back to me. Also, I'm wondering if just changing the DSP will improve the original audio system since I don't like it. I'm considering the Pioneer 500A, which can connect directly with the original plug without installing separate loudspeaker wires.
When braking to a low speed, there's a metallic noise. Does anyone know what's going on??? The brake pads were just replaced two or three months ago.
Hey car enthusiasts, I've got a 2012 Mazda 5 that's had its gearbox repaired. How long can it last? Just bought it second-hand.
The rear tail light on the driver's side doesn't light up when I brake. I just replaced the bulb half a month ago, and now it's not lighting up again. The previous inspection said it wasn't a bulb issue. Has anyone else experienced this? What's the problem?
Is the two-door version of the Jeep Wrangler worth buying if I'm traveling solo across the country at 36, without carrying too much luggage and not planning to go off-road? Just asking fellow car enthusiasts if this car is worth it or if there are better recommendations. I don't like large or long vehicles.
Braking Dipping. I'm considering getting a standard 911. After a test drive of the 4S, I noticed a braking dipping issue. Even if I slowly release the brakes at the last moment, there's still a forward lurch just before coming to a stop. My current Mercedes doesn't have this issue, and neither did the Panamera I test drove earlier. Is it a matter of selecting the wrong mode, or is the car designed this way?
I noticed occasional vibrations in my Murano at around 20,000 km, and the vibrations don't last long. When I went to the dealership for maintenance, they mentioned that they could replace the mid-section improvement part with a bracket for free. Has anyone had this replaced? How does it feel after the replacement?
Why does the windshield washer fluid in my 2024 Arrizo 5 run out after just spraying three to five times? I've refilled it three times in a month and used it only about 10 times in total, each time just 1-2 sprays. Could the bottle be leaking? 😂😂😂
Hyundai Hyundai Accent
Hyundai AccentAED 40,979 ~ 70,404Gasoline
