خالد ظافر
2024-04-05 22:36
When driving at low speeds over rough roads or speed bumps, and then accelerating, the RPM between 1100 to 1500 feels like it's cutting out. Once the throttle picks up, everything returns to normal.
I have a 2021 2.0F1A manual Euro Victory, and when I shift from 2nd to 3rd to 4th gear and accelerate, there's a clicking sound between 1100 and 1400 RPM, like it's low on oil. Does anyone else experience this? Once the RPM reaches around 1500 and the turbo kicks in, the sound starts to decrease. The 4S shop upgraded the ECU, but the sound is still there, whether the AC is on or off.
Hey car enthusiasts, does your KIA Pegas have the rear end wiggle when going over speed bumps or uneven roads while turning? My car is pretty stable at 120 on the highway, but when taking a turn and encountering such conditions, the rear seems to wiggle a bit. I've done the wheel alignment, but it doesn't seem to help.
My Scirocco feels jerky when shifting in S mode. At half throttle, it reaches 4000 RPM and reports an engine fault that needs repair. The EPC light is on, and it mentions something about oil pressure and the engine's maximum speed at 4000 RPM. What's going on, experts? Once I restart the car, everything seems fine (after the car is warmed up, with both water and oil temperatures up to normal levels).
Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
Hey everyone, what’s the fuel consumption of your Alto automatic? I feel mine is too high, 24.5 liters only covers about 300 km. The light came on at 287 km. Also, my idle speed when starting cold is around 1500, but it goes back to 1100 once the engine warms up. Is this normal for fuel consumption and idle speed?
In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦‍♂️
Do you feel that the chassis of your Xiaoqi feels a bit loose when going over rough and hard surfaces, like uphill and downhill? Mine feels a bit loose, and it's only 20,000 kilometers in. I usually don't drive on rough roads, just once on a mountain road with stone slabs and once over a speed bump in the parking lot, and it didn't feel good.
After driving the Venza over bumpy roads, there's always a strange noise coming from the trunk, like something is rubbing or hitting against each other. The same noise happens when turning or going over speed bumps. I've removed all the tools from the trunk and taken off the plastic covers, but the noise is still there.
Hyundai Hyundai Accent
Hyundai AccentAED 40,979 ~ 70,404Gasoline
