What could be causing the engine to make a ticking sound?
What could be causing the whirring electrical sound in my Mazda 2 when the RPM increases?
My 2018 car's engine has started making a ticking sound recently. What's going on?
4Is there anyone with a Levante experiencing a ticking noise when idling after warming up the car? The noise disappears when you press the accelerator a bit. What could that sound be?
5What could be causing the Luxgen M7 engine to make a knocking noise when cold, but not when warmed up?
6The engine of the 2014 GS5 is making a squeaking noise. What could be the problem?
7I've replaced the control arm ball joints, steering rack, and shock absorbers, but the chassis still makes a thumping sound. What could be causing this?
8Hi, what could be causing the steering wheel to make a buzzing sound when turning?
9When the trunk of the Peugeot 301 is opened and then closed, the dashboard makes a ticking sound, similar to the sound of hazard lights. Does anyone know why this happens?
10What could be causing this issue with the 2011 Volvo C30? When shifting to 2nd gear, the engine makes a buzzing noise. There are no fault codes, but there is a throttle body fault code for the engine.
