Today, my car sometimes shakes while driving. It shakes for about 2 minutes and then goes back to normal. Anyone know what the issue might be? Thanks in advance!
Does anyone know why the Yashenti dashboard needles suddenly drop to zero while driving and then return to normal after 1-2 seconds? Thanks, everyone.
What could be causing the steering wheel of my 2009 Lancer Sport to shake left and right while driving normally?
4I've got a 2012 XV and while driving, the hill assist light turns on, then goes off, and comes back on again. Does anyone know what might be causing this? Has any fellow driver experienced this and how did you resolve it?
5Does anyone know why the suspension rises to the highest level when parked and then drops back to normal after a while?
6Hey everyone, does anyone know why a car would suddenly brake uncontrollably for a moment while driving normally, and then go back to normal? Any ideas?
7Hello everyone, when I start my car cold, it makes a "dada" sound and the RPM goes up to over 1000, but it goes back to normal after about a minute. Is this normal?
8It's normal for the idle speed to fluctuate when you turn on the air conditioning in a 2013 1.6 manual fashion model. Sometimes the RPM might go up to around 900 or almost 1000, and other times it might be around 800. If you restart the engine and the RPM goes back to around 800, it's usually not a cause for concern.
9Is it normal for the car to shake when downshifting from 3rd to 2nd gear while braking?
10Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
