The self-check light on the Accent's dashboard isn't lighting up? And there's no engine warning light either.
Hey experts, the head-up display isn't lighting up and I can't turn off the engine. What should I do?
Why is the dashboard indicator needle not lighting up?
4The self-check fault light is not on, everything else is normal.
5Does the Accent have a feature where the warning light turns on if the seatbelt is not fastened?
6The 4LO warning light and the engine light on the Land Cruiser are both flashing.
7Is your Jetour X90 Manual Enjoyment 6-seater not showing the oil light on the dashboard during the self-check before starting the engine? Does it remain off even after starting the vehicle? Are you guys experiencing the same issue?
8What's going on with the 2014 Peugeot 308 dashboard warning light?
9The dashboard shows a warning light, and when checked with a computer, it indicates an ignition module issue. Should I replace the ignition coil? There are no problems when driving normally.
10When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
