The self-check fault light is not on, everything else is normal.
The self-check light on the Accent's dashboard isn't lighting up? And there's no engine warning light either.
Why is there a beeping sound 3 times in a row while driving, even though everything on the dashboard appears normal?
4The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
5Is your Jetour X90 Manual Enjoyment 6-seater not showing the oil light on the dashboard during the self-check before starting the engine? Does it remain off even after starting the vehicle? Are you guys experiencing the same issue?
6My car is 3 years old and sometimes it shows a right front indicator fault, but then the warning disappears. I've had it checked at the shop, but they couldn't find the cause. Has anyone else experienced a similar issue?
7Only the driver's side keyless entry is working, and I've checked the settings, everything seems fine. The auto start-stop isn't activating anymore either, though I don't really use it. Has anyone else encountered the same issues?
8When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
9I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
10The charging station's fault light is flashing, and it cannot charge normally.
