غازي فهد
غازي فهد
Nov 26
The battery is new, and the car starts fine when it's cold. But after driving for about ten minutes, sometimes when I stop and try to restart, it makes a squeaking sound and won't start. If I turn it off and then gently start it again, it works. I'm asking if anyone knows what might be causing this issue and if anyone has experienced something similar?
حسين عدي
حسين عدي2021-12-09 05:35
It seems like the oxygen sensor needs to be replaced.
محمد يعقوب
محمد يعقوب2021-12-06 23:04
Mine too [facepalm]
Is it normal for the 2008 imported Mazda 3 to have a cold start RPM of 1600, with a particularly loud noise that decreases after about a minute?
Is there a delay when starting the Renault Koleos 2019 model in cold weather? Has anyone else experienced this, and how did you solve it?
Why does the car show a transmission fault warning during a cold start, but it goes away after waiting and restarting?
Hello everyone, I'd like to ask something. When I cold start my car, the idle speed is quite high and when I release the brake, the power is strong and it just surges forward. But after driving for a few minutes or waiting at a few traffic lights, it starts to lose power. When I release the brake, it moves very slowly, and it only gets a bit better if I press the accelerator. It's a 2007 model with an automatic transmission.
Is the engine of the 2018 automatic model noisy while driving? Has anyone experienced something similar?
Hello everyone, when I start my car cold, it makes a "dada" sound and the RPM goes up to over 1000, but it goes back to normal after about a minute. Is this normal?
What could cause a car to shake when starting cold?
I didn't drive for two days, and when I started the car today, I noticed the engine warning light was on. For the first ten minutes or so, pressing the accelerator only increased the RPM, and the speed stayed below 20. After driving for about ten minutes, when I pressed the accelerator, there was a humming noise, and the speed gradually picked up. However, the fuel consumption display kept changing even when the car was parked or just started and not moving (or maybe I hadn't noticed this before). Can anyone advise what's going on? Has anyone experienced this before?
When starting the Santana 1.5 automatic Trendline, the auto start-stop makes a squeaking sound. Does anyone know what's going on? Thanks, everyone!
If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
Hyundai Accent
Hyundai AccentKWD 3,438 ~ 5,908Gasoline & Petrol
