سلمان زاهر
2024-07-02 22:50
The 2009 Accent has a wheel with 4 lug holes. If you're considering changing the wheels, you can, but make sure the new wheels are compatible with your car's specifications.
You can purchase welcome lights for your MDX from online retailers such as Amazon or eBay. Additionally, you may find them at automotive parts stores or websites that specialize in car accessories. Make sure to check the product specifications to ensure compatibility with your vehicle model.
You can consider upgrading the wheels on your Subaru Liberty Wagon to a larger size to prevent scraping against the chassis and front end. Typically, people upgrade to 17 or 18-inch wheels for better clearance and aesthetics. However, make sure to check for compatibility with your vehicle's suspension and wheel well space, and consult with a professional to ensure safety and performance.
If you're considering changing the tires for your Kia Pegas, it's best to choose a brand that is known for quality and performance. Popular tire brands like Michelin, Bridgestone, and Goodyear are often recommended for their reliability and durability. Make sure to select tires that match the specifications and size needed for your vehicle to ensure optimal performance and safety.
To reset the oil light on an Acura RDX, follow these steps: 1. Turn the ignition to the "ON" position, but don't start the engine. 2. Use the steering wheel buttons to find the "Settings" menu on the display. 3. Navigate to "Maintenance Info" or "Oil Life" using the arrow buttons. 4. Press and hold the "Reset" or "Select/Reset" button until the oil life resets to 100%. Make sure to consult your vehicle's owner's manual for any model-specific instructions.
You're considering buying a 2009 automatic Kia Sportage, which was purchased in 2022 in excellent condition for over 40,000. Now, you plan to offer around 13,000 for it. Is it worth buying?
If you want to modify your tires without changing the 17-inch diameter, you can consider changing the tire's width or profile. You can opt for a wider tire for better grip or a different profile for improved performance. Just make sure the new tires fit your vehicle's specifications and don't affect the overall driving experience. It's always a good idea to consult with a professional or refer to your vehicle's manual for recommendations.
I'm considering replacing the front bumper with a short ARB one, but I'm not sure if it can accommodate radar holes. The JL bumper has 6 radar sensors. Has anyone here modified theirs and can offer some advice? Thanks!
If you're considering buying an RDX, it's generally recommended to look for models from recent years as they tend to have the latest safety features and technology. When choosing between a two-wheel drive (2WD) top trim and a four-wheel drive (4WD), it depends on your driving conditions. If you're mostly driving on highways and in urban areas, a 2WD might be sufficient and could offer better fuel economy. However, if you want extra traction and stability, especially in adverse weather conditions, a 4WD would be a safer option. In terms of safety, newer models typically have more advanced safety technologies. Always check the specific safety features available in the model year you're considering.
Has anyone bought the 2025 model in black and then changed it to a black and gold combo? I'm thinking about buying the black one and changing it to black and gold, but I'm not sure how to make it look good!
Hyundai Hyundai Accent
Hyundai AccentAED 40,979 ~ 70,404Gasoline
