حسن بلال
2020-08-02 23:26
My Hyundai Accent's front left shock absorber makes a squeaking noise on uneven roads, but there's no noise on flat surfaces. Why is that, and how can I fix it?
خالد ظافر
خالد ظافر2021-10-11 21:53
It's likely an issue with the stabilizer bar bushing.
لحود فهد
لحود فهد2021-10-11 10:14
Mine too, and the steering wheel makes a squeaking noise when turned all the way.
عدي عمر
عدي عمر2021-10-10 08:11
Just replace the ball joint and tie rod.
حسن صلاح الدين
حسن صلاح الدين2020-08-13 22:46
I have the same issue. I changed the ball joint, but it's still making noise.
نايف جابر
نايف جابر2020-08-03 00:24
It is likely that your car's suspension system is either loose or lacking oil. You need to lift the car and inspect the system to determine the exact issue.
Is there anyone who has changed the rear shock absorbers because of abnormal noise and excessive stiffness?
Hi everyone, could someone guide me on how to replace the rear left interior handle of a Hyundai Accent?
What could be the reason for a 2015 car making squeaking sounds when driving on uneven roads?
Why does the car make a humming noise at 40 mph? The noise is very loud, and the shock absorbers have been replaced.
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
Guys, many people are saying that the GV80 has issues with bumpy roads and uneven surfaces. Is this true? How can we go on road trips then? Could it be a problem with their mode settings or the electromagnetic suspension?
When the Sportage makes a thumping noise over uneven road surfaces, what's the issue?
2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
Hyundai Hyundai Accent
Hyundai AccentAED 40,979 ~ 70,404Gasoline
