سلمان يوسف
2023-01-28 18:58
My Accent's new steering belt gets loose after a few days, and then starts slipping with a squeaking sound. Does anyone know what's causing this?
سلمان إلياس
سلمان إلياس2023-03-29 06:43
Replace the belt tensioner.
2
أحمد علي
أحمد علي2023-03-28 19:34
My car also makes a sound, sometimes a squeaking noise. Sometimes it doesn't.
The battery is new, and the car starts fine when it's cold. But after driving for about ten minutes, sometimes when I stop and try to restart, it makes a squeaking sound and won't start. If I turn it off and then gently start it again, it works. I'm asking if anyone knows what might be causing this issue and if anyone has experienced something similar?
My MG GT experiences jerky acceleration, and there's a squeaking sound when I turn the steering while driving. Additionally, there's a squeaking noise when I rev the engine after parking. What could be the issue?
Hello fellow car enthusiasts, I own a Patrol Y62. A few days ago, while driving, the lower ball joint on the left rear wheel suddenly broke. Do you know what might have caused this?
Does anyone know why there's a high-pitched buzzing sound inside the car as soon as it's powered on? It's been happening the last few days and it's giving me a headache.
I've replaced the control arm ball joints, steering rack, and shock absorbers, but the chassis still makes a thumping sound. What could be causing this?
My 10-year-old 1.6 manual Peugeot 307 sometimes makes a sharp "squeak" sound, like metal rubbing against metal, when I'm shifting gears, releasing the clutch, or letting off the accelerator. Does anyone know what might be causing this? 🥲
Hi, what could be causing the steering wheel to make a buzzing sound when turning?
The sound of rustling near the throttle belt on a 10-year-old Alto could be due to several reasons. It might be caused by a worn-out or loose belt, debris stuck in the belt area, or possibly an issue with the belt tensioner. It would be best to have it inspected by a professional to determine the exact cause.
I have a new KAMIQ and will be getting the windows tinted in a couple of days. Should I go with the free tinting or pay extra for an upgrade?
Hyundai Hyundai Accent
Hyundai AccentAED 40,979 ~ 70,404Gasoline
