Is it normal for the clutch of a 2009 Accent to have some play at the beginning when you press it?
The clutch of my 2018 Foton Tunland E5 was recently replaced, but there's always a burning smell while driving. Additionally, there's a strange noise when I'm not pressing the clutch, which disappears when I do press it. What could be the cause of this?
When the car is in D gear at idle, it feels weak (like an ant crawling), but when you press the accelerator, it becomes normal. In reverse gear, it doesn't move at all unless you press the accelerator. The car is a 2016 Haima S5.
Does a 2009 Accent key have a chip? I want to get a copy, thanks.
4Is it normal for the clutch of a 2009 Accent to have some play at the beginning when you press it?
5Is it normal for a 2009 Liana valve cover gasket to have oil seepage and sludge buildup?
6When I press the clutch, there's a squeaking noise, but it goes away when I release it. Is there a problem?
7I have a 2009 Accent. Why does the car stall every time I press the clutch?
8I have a 2009 Touran 2.0 manual, and I'm having trouble shifting into first and reverse. Is anyone else experiencing this? Also, when I release the clutch in first gear, the engine shakes like it's about to stall. It also shakes a bit during rapid acceleration. Is this normal?
9Hey everyone, I've been experiencing some jerking when I press the clutch on my car. What could be the reason for this? It happens when I try to shift gears at 2000 RPM.
101. Does anyone know if it's normal for there to be a "thud" sound when quickly releasing the clutch from first to second gear in a manual Suzuki Swift? 2. When pressing the clutch to engage first gear, sometimes there's a "thud" sound near the left foot. What's the issue?
