Is it necessary to replace the sensor if there's an oxygen sensor 2 circuit fault?
For the 2011 Suzuki Liana, if you're getting a catalytic converter fault warning, there are a few things you can consider. First, you might want to confirm the diagnosis with another mechanic to ensure it's indeed the catalytic converter that's the issue. Sometimes, other components like oxygen sensors can also trigger similar warnings. If replacing the catalytic converter is necessary and the cost quoted is over two thousand, you might want to compare prices from different repair shops or consider aftermarket parts, which can sometimes be more affordable.
The fault code shows two P0420s, one yellow and one red, both indicating the first bank. Is it the catalytic converter that's faulty or the oxygen sensor?
4Is it necessary to change 2 liters of oil for a Lancer each time?
5Why does the engine light keep coming on in my 2017 Kia Pegas automatic? After resetting, it lights up again after driving for a while. I've already replaced the oxygen sensor, but the problem remains.
6Hey guys, my car is showing error code P048013, which is about fan 1 control circuit, general electrical fault, open circuit. Has anyone encountered this error code before? Thanks.
7Guys, can you help me figure out what I need to replace here? It's giving me a headache!!! "Jeep Liberty reports C121C Torque Request Signal Denied, first issue." "Crankshaft/Camshaft Timing Misalignment - Bank 1 Sensor 1 - Powertrain Control Module (PCM) fault code: P0016, this is the second issue." "Camshaft Position Sensor Circuit - Bank 1 Sensor 2 - Powertrain Control Module (PCM) fault code: P0365, this is the third issue." "Camshaft Position Sensor Intermittent - Bank 1 Sensor 2 - Powertrain Control Module (PCM) fault code: P0369." "Bank 1 Camshaft 2 Position Slow Response - Powertrain Control Module (PCM) fault code: P000B." "Torque Request Signal Denied - Anti-lock Braking System (ABS) fault code: C121C."
8Changan Alsvin, ABS and anti-skid faults, diagnostic shows left front wheel speed sensor fault. I replaced it, but the lights are still on. The diagnostic still shows left front wheel speed sensor fault, but all the data streams are there. The fault can be cleared, but it comes back while driving. What should I do?
9Changan Yuexiang, ABS and anti-skid fault, diagnostic shows a left front wheel speed sensor fault. I replaced it, but the lights are still on, and the diagnostic still shows the left front wheel speed sensor fault. However, all the data streams are present. The fault can be cleared, but it comes back while driving. What should I do?
10Where is the oxygen sensor located in a KAMIQ?
