Is anyone experiencing unstable idling with their car? How did you solve it?
Have you ever experienced unstable idling? Any solutions to fix it?
Is anyone else experiencing unstable idling with the new BRZ? Even without the AC on, whether the car is cold or warm, the gauge needle fluctuates noticeably.
For manual transmission, has anyone experienced the issue of the clutch not returning? How did you solve it? Should I replace the slave cylinder or the spring?
4Is there a delay when starting the Renault Koleos 2019 model in cold weather? Has anyone else experienced this, and how did you solve it?
5Is there anyone with a 2020 GA8 experiencing occasional engine shaking and exhaust fault codes? How did you solve the problem?
6Is anyone experiencing vibration from the sun visor area in the 2028 Mitsubishi ASX when driving over 80 km/h? How did you solve it?
7Is there anyone who has experienced noise from the passenger side when turning on the air conditioning in the 2019 GAC GA6? How did you solve it?
8Airbag warning! Has anyone experienced this? How did you solve it? My car is out of warranty, so I'm asking online!
9Hey guys, anyone experienced issues with the VVT wheel sticking on the 2020 Jetour X70 exhaust? How did you solve it?
10Has anyone else experienced the issue where the car's data is turned off by default these past two days, and you have to manually turn on the network? How did you solve it?
