عمر عَبْدُ الْعَزِيز
2022-02-27 15:14
If I leave my car unused for three days, the battery dies. How long can your cars sit without losing charge? I'm thinking of getting an emergency jump starter. Could you recommend a good brand? Thanks!
Comments( 6 )
حسين عيسى
حسين عيسى2022-05-30 10:33
Even if you remove the anti-theft fuse for one or two months, it can still start.
خالد موجا بطاقة تعريف
خالد موجا بطاقة تعريف2022-05-17 23:39
I'm on a business trip for a month, no worries! [Yay]
لحود فهد
لحود فهد2022-03-11 17:54
Replace the battery.
محمد زين
محمد زين2022-03-10 18:20
If you're not using it, I suggest disconnecting the battery cable.
أحمد تكريتي
أحمد تكريتي2022-03-06 12:47
Find a mechanic to check if there are any issues with the battery and the motor.
خالد ظافر
خالد ظافر2022-02-27 15:34
Change the battery. It's a hassle and costs more money. That thing isn't cheap either.
The tire loses air slowly, needing to refill every three to four days, but the tire isn't damaged. What could be the reason?
I have an HS7 at home. I'm considering buying a new energy SUV. I don't go out often, but when I do, it's usually a long trip (at least 2 hours). My friends have recommended brands like Li Auto, NIO, and AITO, but I'm thinking about the HS9. However, I've heard it doesn't have a good reputation. I'm here to seek advice on the following aspects and would appreciate genuine feedback and evaluations: charging speed, charging pile installation, material quality, human-vehicle interaction, intelligence, maintenance, and actual range. Thank you, everyone.
Here’s the situation: I just replaced the battery, but it's dead again. After starting the car, after a while, it reports a battery charging fault. Then the ABS and airbag lights also come on. When idling in place, after a while, the car will automatically shut off. When driving, it feels like it doesn't shift gears automatically, and I can't switch to manual mode either. Vehicle: Peugeot 207 1.6 Automatic. The battery wasn't great initially, and I didn't pay much attention to it, usually jump-starting the car. A few days ago, I replaced the battery. First, during driving, it started showing a battery charging fault. After a while, the ABS light came on, then the airbag light lit up as well. It's like a parade of warning lights. Now I'm wondering if it's worth repairing. What could be the issues?
How's your car battery? Mine won't start after sitting for three days. Any advice?
Hi everyone, I've been having issues with my Hongqi H7 where the side mirrors often don't fold when I lock the car and the seat adjustment occasionally fails too. I noticed these problems tend to occur together. I had the wiring checked and charged the battery, which fixed it for a while, but then it started happening again. I thought it might be the battery losing charge, so I replaced it. It was fine at first, but then the problems came back. The mirrors fold manually without any issues inside the car; it's just when I lock the car that they don't fold, and the seat adjustment also fails!
Is it normal for a car to lose its battery charge after being parked for a few days?? Please share your thoughts.
I need some guidance from the experts. I'm new to cars and currently, my family doesn't own one. My husband works nearby, but I commute 40 kilometers to the suburbs for work every day. We live in an old neighborhood without home charging facilities, and I'm thinking of buying a new energy vehicle. I've had my license for six years but haven't driven much. I liked the appearance of the Zeekr X but heard the rear space is small. Personally, I like Zeekr and Ora, and I'm also considering Deepal. I'm really confused and don't know which car to buy. Any advice from the experts would be appreciated.
There's a bug in the fuel consumption mileage stats of the Nissan X-Trail EP, which causes it to reset automatically. This has happened a few times, and each time all the data on the "Since Last Refuel" page gets cleared. I'm not sure if it's a bug. It's still hard to pinpoint the exact conditions for the issue to reoccur, but I can confirm it should include the following: 1. Long periods of idling without turning off the engine 2. Unlocking the car doors 3. Leaving the car with the key (out of sensing range) Then, when you return, you'll find the data has reset. This has happened three times, and looking back, it was pretty much under these circumstances.
Hyundai Hyundai Accent
Hyundai AccentAED 40,979 ~ 70,404Gasoline
