I've reached 100,000 kilometers. Do I need to replace the clutch kit?
Do I need to replace the timing chain at 100,000 kilometers?
I've driven 80,000 kilometers. Do I need to change the transmission oil? Which brand of oil should I use?
4Is the clutch on the 207 particularly high? Should I replace the clutch kit, or is this normal for the car?
5Does the timing chain of a 2013 MG3 need to be replaced? It's only been 100,000 kilometers. Has anyone changed it before?
6Hello everyone! My 11-year-old Sunny with a manual transmission has run 100,000 kilometers. Do I need to change the belt now?
7Is the clutch very heavy? Do I need to replace the clutch kit, or should I replace something else? Or is this normal? It's a 2014 model with over 200,000 kilometers, and I just got it as a used car.
8Kia Cerato 2018, manual transmission. I've replaced the clutch kit twice, but the clutch still feels heavy. It's almost 90,000 km now. How do you guys solve this? 😩😩😩
9What maintenance should be done at 100,000 kilometers? Do the transmission oil and gear oil need to be replaced?
10What maintenance does a 2018 Jetta need at 100,000 kilometers?
