محمد زيد دين
محمد زيد دين
Jul 13
I have a 2006 Accent, and the current issue is that it won't start. The engine cranks normally when trying to start, and there are no warning lights. However, it can be started by pushing. I've checked the wiring, fuel line, and starter, and everything seems fine. The mechanic here replaced the spark plugs and fuel pump assembly, but it still won't start! Can any expert advise me on this? 🙏
عبدالله فواز
عبدالله فواز2022-04-23 08:35
Issue with the computer board.
محمد زيد دين
محمد زيد دين2020-07-13 22:57
Throttle body cleaned.
حسين كم
حسين كم2020-07-13 16:19
This is probably caused by an issue with the throttle, leading to poor air intake. This situation can cause such problems.
After a major maintenance on the 2006 Accent 1.4 manual, the spark plugs, carbon canister solenoid, and throttle have been replaced, and the fuel injectors have been cleaned. With the fuel price at 7.91, it's costing 0.9 per kilometer. Is this normal? The oxygen sensor is fine!
Hey everyone, my 2011 Accent sometimes won't start after parking, but if I wait for about 10 or 20 minutes, it starts up again. What's going on?
Why does a 2006 Accent manual consume so much fuel? Filling up the tank for 340 RMB only allows it to run 450 kilometers.
Hey everyone, I have a 2006 manual Mitsubishi Lancer. The fuel gauge needle is below the red line, but the fuel warning light isn't on. Is it normal for this car not to light up? Also, is there a nationwide car owners group?
Has anyone experienced starting issues with their car? This problem has been going on for over a year. I've replaced the battery, cleaned the fuel lines, changed the spark plugs, and replaced the fuel pump, but still can't find the issue. The dealership is also at a loss. Every time I try to start the car, it takes three attempts to get it running. It feels like the fuel isn't reaching the engine when starting. I'm now afraid to drive, because if the engine stalls, it'll take three attempts to start it again. 😢😢😢 Does anyone know the reason?
It was working fine yesterday, but this morning it won't start. Does anyone know what could be the problem? Could it be because of the low temperature last night? The starter seems weak. 🙏🏽🙏🏽🙏🏽🙏🏽
Hey Alto friends! After I connected the reverse radar wires myself, the car started twice without any issues. But after I arranged the wires, it won't start anymore! Does anyone know what might be causing this?
What could be the reason that the MG ZS won't start with the push button?
My relative gave me a 2006 Peugeot automatic 1.6L 307. A few days ago, it was running low on fuel (almost to the red line), and the range showed there were 60km left. Suddenly, it made a "ka" sound and everything stopped, showing something about "gearbox." After turning it off and restarting, it was fine, and adding fuel prevented the issue from happening again. Should I get it checked? The mileage was over 60,000 when I got it, and now it's at 88,000. Seeking advice from the forum experts.
Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
Hyundai Accent
Hyundai AccentQAR 40,661 ~ 69,900Gasoline & Petrol
