أحمد خد
أحمد خد
Dec 13
I bought an '09 Accent and it's burning oil. What should I do? At 80 mph, the RPM is over 2000, and when I accelerate more, it vibrates a bit. Is there a problem? Can it go on the highway?
أحمد علي
أحمد علي2023-02-17 23:07
What is the normal RPM at 80? It seems like my car is burning some oil too.
2
خالد ظافر
خالد ظافر2023-02-16 23:14
First, check if the check valve is faulty. If it's not, then inspect the valve seals.
I bought a used Liana and it's burning oil. What should I do?
How does the FJ perform on the highway? What's the engine RPM at a speed of 120 mph?
Hey fellow car enthusiasts, I just got an '09 Mazda2. I wanted to ask if there are any common issues I should be aware of. Also, is the Mazda2 prone to burning oil? I'm really concerned about the oil burning issue. Thanks!
Are there any GV80 owners experiencing a vehicle vibration issue transmitted to the pedal and steering wheel at around 1500 RPM before each gear shift, while driving at a speed of 40-80 mph?
I just got a 2013 model with a 1.6 manual transmission. Everything else is fine except there's a loud buzzing vibration sound around 2000 RPM in every gear. Before or after hitting 2000 RPM, it's normal again. Has anyone else experienced this? How can it be fixed? Any advice from the experts would be appreciated.
Has anyone's particle filter gotten clogged? Mine clogs once a year, it's really troublesome. This car doesn't burn it off even on the highway, rarely goes over 2000 RPM, so it basically can't burn off. How do you guys deal with it? Do you just run it in third gear at 6000 RPM to clear it?
Is it normal for a 2015 Nissan Sunny manual transmission, with 80,000 kilometers, to have the RPM at 2000 when going over 70 mph in fifth gear?
Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
Hyundai Accent
Hyundai AccentEGP 231,900 ~ 969,988Gasoline & Petrol
