Has anyone ever replaced the rear wheel bearing on Xiaoya?
Hey everyone, I have a 2011 Mazda5. There's a humming noise between 40 to 80 km/h. The bearings on both sides are fine, and the center support bearing has been replaced. Has anyone else experienced this issue?
Has anyone driven a rear-wheel-drive SUV? If you haven't driven a rear-wheel-drive, do you need to go for a four-wheel-drive?
4Guys, can the rear seats be replaced with aviation seats? Has anyone done this modification?
5Has anyone here ever replaced a transmission? What issues can get you a warranty for the transmission?
6Has anyone ever encountered an intentional light code?
7Is it normal for the rear wheel bearing to fail after 37,000 kilometers?
8Has anyone ever changed the hydraulic oil for the chassis lift on an LC100 4700? How do you replace it?
92018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
10Why can't I bear to replace the WSJ?
