For a 2007 model with an automatic transmission and a sunroof, what could be the issue if the tailgate can only be opened with a key? Fellow car enthusiasts, any ideas? Also, which model do I have? It doesn't completely match any listed on the home site. [Facepalm]
2011 model, the alarm goes off when unlocking. What's going on, any ideas?
The 2018 Rolls-Royce Ghost Extended Wheelbase, with 12,000 kilometers driven and having been impounded by the court for nearly three years, would have its value affected by several factors. These include its condition after being impounded, market demand, and any depreciation over time. For an accurate valuation, I would recommend consulting with a professional appraiser or checking the current market listings for similar models.
4After locking the 2.0 manual ASX, the remote works fine, but why can't it be opened with the key? Any ideas?
5You have a 2016 model with a CVT transmission, but you're not sure which version it is. You can usually find this information in a few places: 1. **Owner's Manual**: The manual that came with the car often lists the specific version or trim level. 2. **VIN Number**: Locate the Vehicle Identification Number (VIN) on your car and use it to check online databases or contact the manufacturer for detailed information about your car. 3. **Door Jamb Sticker**: There is often a sticker in the driver's side door jamb that includes details about the vehicle, sometimes including the model version. 4. **Service Records**: Check any service or maintenance records you have for your vehicle, as they might list the specific model version. 5. **Dealership**: Contact a dealership with your VIN number, and they can usually provide detailed information about your car.
6Are there any 2011 models that have been modified with keyless start? [Facepalm][Facepalm][Facepalm]
7Are there any owners of 2019 two-wheel drive or four-wheel drive luxury models here? I have a question. For models where only the driver's window has the one-touch up/down feature, can you long-press the lock button on the key to raise the windows? Can this be upgraded at the dealership? My 2019 four-wheel drive luxury model can only close the sunroof with the key, not the windows.
82022 HONGQI HS7 QiChang with five seats, driven 8000 miles. After rain, the keyless entry system failed. The key can only lock and unlock the doors; inside the car, the key is not recognized (both keys have this issue), and the car won't start (even emergency start doesn't work). HONGQI Smart Connection can start the vehicle, but it can't be driven away. The 4S shop inspection indicated a key matching fault, and after re-matching, it worked fine. However, the issue reoccurred 5 days later. What could be the problem? Have any fellow car enthusiasts experienced this? How do you deal with it?
9Hi everyone, I have a 2017 GA8 Premium model, which I believe has front radar. However, I have no idea how to use it. It never seems to activate while driving. Can anyone tell me in what situations the front radar gets triggered? Or is there some button or switch that I need to press to activate it? [Facepalm] Seeking help from the experts here! [Pray] [Pray] [Pray]
10Hello everyone in the Leapmotor community, I have a question. Can you unplug the charging gun during slow charging at home? This morning at 6 o'clock, while I was sleeping and the car was charging, my father needed to use the car. He directly unlocked and unplugged the gun to drive away. This raises my doubts: Can the Leapmotor C11 pure electric model be directly unplugged during slow charging? First, does this operation pose any threat to personal safety? Second, will this affect vehicle safety? Third, will it impact the battery? If it's an incorrect operation, how should one correctly stop using the car during charging?
