صعدة نايف
2021-12-04 19:17
After a major maintenance on the 2006 Accent 1.4 manual, the spark plugs, carbon canister solenoid, and throttle have been replaced, and the fuel injectors have been cleaned. With the fuel price at 7.91, it's costing 0.9 per kilometer. Is this normal? The oxygen sensor is fine!
Comments( 8 )
عبد العزيز عثمان
عبد العزيز عثمان2022-11-22 14:29
If it's because of the AC, then it's not surprising. But if it's not, just wait a while and the fuel economy should automatically improve.
فهد رأس
فهد رأس2022-10-29 21:25
My experience is similar to yours. With the current fuel prices, 100 yuan only gets me 100 kilometers as well.
نايف أنيس
نايف أنيس2022-10-05 11:45
That must be expensive. My '09 model doesn't have a catalytic converter. It's always full throttle. It costs about 0.7 RMB per kilometer.
أحمد تكريتي
أحمد تكريتي2022-08-13 17:49
Try adding some fuel additive.
علي طلحة
علي طلحة2022-07-22 13:05
Is it fixed now?
أحمد تكريتي
أحمد تكريتي2022-03-06 12:43
A person is the same.
خالد ظافر
خالد ظافر2021-12-05 17:20
Mechanical throttle bodies typically don't fail. Let's focus on the fuel injectors; they generally don't need cleaning. This car has a few instances of significantly high fuel consumption. Generally, it averages around 6 liters per 100 km, with automatic models around 7 liters.
لحود فهد
لحود فهد2021-12-04 22:28
It's quite expensive, huh?
Is the fuel consumption for the 2009 Liana 1.6 automatic reaching 10 liters per 100 kilometers because of a faulty oxygen sensor or carbon canister purge valve? I've checked the spark plugs and ignition coil, and there are no issues. Any advice from the experts?
When coming to a stop, the idle speed suddenly drops and it feels like the car is about to stall. This occasionally happens when shifting from D to P while stationary. I've replaced the spark plugs, ignition coils, injectors, high-pressure fuel pump, PCV valve, carbon canister solenoid, air flow sensor, and engine mounts. I've also cleaned the intake carbon deposits and combustion chamber carbon deposits. The problem still exists. Can anyone help me figure this out? [crying][crying][crying][crying]
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
Why does a 2006 Accent manual consume so much fuel? Filling up the tank for 340 RMB only allows it to run 450 kilometers.
Recently, my fuel consumption has suddenly increased significantly. I suspect it might be the carbon canister purge valve. How should I check it? Can any experts help out?
What is the normal fuel consumption per 100 kilometers for a 2010 Hyundai Accent with a 1.4-liter engine given the current fuel prices?
Does anyone know about the 2013 ASX 1.6 manual having issues with fuel tank overflow and carbon canister leakage causing the car to stall?
I've been driving a Suzuki SX4 for over ten years, and now the fuel consumption is higher than before. When I press the accelerator, the RPM goes up, but the speed doesn't increase. I've changed the transmission oil, cleared the engine carbon deposits, and worked on the throttle and fuel injectors, but the RPM is still high while acceleration is slow. Are there any fellow car owners who have experienced similar issues?
Hi everyone, can anyone tell me where the carbon canister solenoid valve is located in the Territory? A picture would be great. Thanks!
Hyundai Hyundai Accent
Hyundai AccentAED 40,979 ~ 70,404Gasoline
