حسين ثاني
2022-07-28 15:59
08 Accent, ABS and brake lights are on. But the car seems fine. What could be the problem?
عبد الحكيم أحمد
عبد الحكيم أحمد2022-07-30 10:35
My 2006 model is the same. I didn't bother with it since the brake fluid level is sufficient.
خالد ظافر
خالد ظافر2022-07-28 17:29
Check the brake light and brake fluid. The ABS issue is likely due to a faulty sensor.
2
What could be the issue with the clutch not being smooth on a 10 Accent?
My X95 manual's headlights have an issue. When I start the car and turn on the high beams, they don't work at all. But for a few seconds, they work fine. When the car is parked and I turn on the high beams, everything is fine. What could be the problem?
What could be the reason for the headlights and brake lights turning on by themselves at night?
What could be the reason that there seems to be something blocking the brake pedal when I press the brake on a 207?
It was working fine yesterday, but this morning it won't start. Does anyone know what could be the problem? Could it be because of the low temperature last night? The starter seems weak. 🙏🏽🙏🏽🙏🏽🙏🏽
The engine warning light is on, and the idle seems unstable. The speed can still go up, but it doesn't accelerate as quickly as before. Could it be a problem with the throttle? Any insights?
Hello everyone, today after the car accident, it showed a transmission fault, and the gear can't be shifted from the P position. It seems like it's locked. What could be the problem?
What could be the issue if the ABS warning light is on in a 2013 Santana 1.4 manual?
I have a 2016 automatic Santana, and the ABS light occasionally turns on and off. When I took it for a check-up, they said there was no problem, and it drives fine. It's just annoying to see the light on. Any idea what's going on?
Hyundai Hyundai Accent
Hyundai AccentAED 40,979 ~ 70,404Gasoline
