This car's air suspension is giving an alert saying that the road surface is unknown and the suspension cannot be adjusted. What could be the issue?
I installed a solar-powered airplane on the dashboard, and now the car keeps giving alerts. How can I turn off the alerts or adjust the sensitivity? [Facepalm]
Hey everyone, the chassis of the GV80 feels too stiff, and the ride comfort is really poor and bumpy. The roads I'm driving on aren't even that bad. It seems like having no air suspension is really an issue. Any suggestions?
4If the car is already started, you can usually drive it even if the key is not inside. However, most modern cars will give a warning sound or display a message indicating that the key is not in the vehicle. This is to alert the driver that the key might be missing. As a chauffeur, if you reach the destination and the owner cannot find the key, it's important to inform them about the situation.
5Guys, many people are saying that the GV80 has issues with bumpy roads and uneven surfaces. Is this true? How can we go on road trips then? Could it be a problem with their mode settings or the electromagnetic suspension?
6What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
7The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
8When driving the Kamiq, if a red "P" appears on the dashboard and there's a beeping sound similar to the seatbelt alert, what could be the issue? Can anyone advise? Thanks!!
9When the Sportage makes a thumping noise over uneven road surfaces, what's the issue?
10When idling in place, the tachometer occasionally fluctuates slightly. What could be the issue, fellow car enthusiasts? On a flat road, when driving in first gear at idle, there is a noticeable jerk. The jerkiness becomes more pronounced when the air conditioning is turned on.
