How can I cancel the tire pressure warning on the EHS9 model when the tire pressure is normal?
How do I reset the tire pressure? 🌹🌹
You can try the following steps to reset the tire pressure warning light: 1. **Check Tire Pressure:** First, ensure all your tires, including the spare, are inflated to the recommended pressure. 2. **Drive Your Car:** Sometimes, simply driving your car for a few miles can reset the warning light. 3. **Use the Reset Button:** Some vehicles have a reset button for the tire pressure monitoring system (TPMS). Check your owner's manual for its location and instructions. 4. **Disconnect the Battery:** As a last resort, you can disconnect the car battery for a few minutes to reset the system. However, this may reset other settings in your car. If the warning light remains on, there might be an issue with the TPMS or a tire. It’s best to consult a professional mechanic to diagnose the problem.
Tire pressure warning
4The tire pressure warning on the third-generation Yuexiang keeps appearing. After driving for a while, it disappears. What's going on??
5How to reset the tire pressure?
6The tire pressure monitoring system suddenly gave an alert, but the tire pressure is normal. I drove 100 kilometers and it still hasn't reset. How can I fix this?
7How to reset the tire pressure display?
8How do I reset the tire pressure after a repair? It still shows low pressure on the right rear tire.
9How can I change the display on the left side of the dashboard screen? Mine always shows a car model, but I've seen others display tire pressure.
10How to reset the tire pressure?
